Mi 4i
295 Hours
Mi BandMi In-Ear HeadphonesMIUI 6I Love MIUIXiaomi Mi 4Mi 4iMIUI Fan from India700K Forum MembersXiaomi 5th AnniversaryMIUI 5th AnniversaryMIUI FB FollowerRedmi Note 3 Explorer
[Tips and Tutorials] [Tutorial] [Fixed] No Data Connectivity on 3G/H+
26671 605 |
15:20, Oct-26-2015 | From PC
This post was edited by miui-guru at 13:43, Oct-28-2015
Hi MIUIers
Connectivity is a word that is definitely not unheard of in the modern world. The importance of being connected to one another has probably never been greater. This is the era of constant connection with everyone. Be it your work, your family or friends, it is absolutely essential for one to be in touch with everyone else at all times. The internet is actually being considered as a basic human right by various organizations that operate on the global level.
But what if you are not being able to stay connected even though you have the Data packs .Yes , this does happen sometimes and its Frustating . You are'nt able to connect to internet even though your Phone Show H+ signal (data transfer).
    My Mi3 had full signals ,its showed H+ but data Transfer was in 0-1 Kb . Custom Roms Didnt had this issue.Later i found that its a issue with wrong Apn settings . So I Made a Stock recovery Flash zip For Mi3/4 which fixes the Apn Bug.
Mi3/4 , Redmi 2/Prime , Note 3G/4G,Redmi 1S  Stock Recovery Zip Added
How to Flash the Zip ?
  • Download the Zip for your Device and rename it to "update.zip"  without quotes
  • Then place the update.zip to the Root directory of Your phone's INTERNAL STORAGE
  • Reboot the Phone to Recovery mode
  • You can power off the phone the press Volme + and power to go to recovery mode
  • Then select the preferred Language and go to recovery menu
  • Then  press install update.zip to system
  • Reboot after succesfull flash .
or
go to Update app and press the three dot menu for options , then press reboot to recovery
(* Note- zip doest flash from updater app only via custom / Stock recovery )
After Reboot
Go to settings > Mobile Networks> Acces Point names
press reset To Default
And now Your MI3 /4 Apn are reset to the fixed apns-config.xml .
Select your Apn and Enjoy .
Other devices
  • Users can use Custom recovery (with signature verification disabled) and flash the Below Zip.
  • Rooted phones can used root file explorer .
  • Download apns-config.xml ( below )
  • Replace the apns-config.xml  with /System/etc/apns-config.xml
  • Change the permission of the file rw - r - r  (0755)
  • Reboot the device
  • Reset Apn to default from settings> Mobile Netwoks > Access point names
DOWNLOAD
  Please reply to view this thread.
Note:
  • Flash it on your risk.
  • If any thing went wrong during this process then I'm not responsible.
  • For devices having TWO systems , flash it to both systems.
  • This zip is tested by users and it is working fine
    Thanks to all tester for  testing and reporting .
Enjoy Miuiers
Favorite14 Share
Comment
arun6199 Support: 5 Objection: 0 it worked! thanks for such great work! tested on mi3w.. service provider:Tata Docomo  02:40, Oct-29-2015
-Light- confirmed it working in MI4  18:19, Oct-26-2015
Rated by 55 people   Experience Prestige Reason
ashu.ashu + 1 Thanks!
andrey@records + 2 Agreed!
Dasari5 + 1 Thanks!
ALSYUNDAWY + 2 Awesome!
Luke_ITA + 1 Awesome!
DavidLia + 2 Thanks!
ravi499 + 5 Awesome!
guffoe + 5 Agreed!
AJIT-REDDY + 1 Thanks!
MiUi_drone + 1 Awesome!
suriiiii + 1 Fantastic!
Anmsem + 1 Great!
Ankit786 + 5 Awesome!
Tukaistar + 1 Awesome!
BondanOwen + 5 Thanks!
paolovs + 1 Great!
zumoku + 1 Great!
due3die + 1 Fantastic!
asharma + 2 Thanks!
lijo_1 + 10 + 3 Fantastic!
babeesh + 1 nice
sa.1985 + 5 Thanks!
leontz + 2 Awesome!
Yashionex + 5 Thanks!
ZZidane + 1 Awesome!
RydhoMS + 5 Thanks for sharing!!
DiLshadSys + 5 Awesome!
Experience +228  Prestige +32  View Rating Log
Miui Guru
MIUI Honorary Moderator
Active on Mi India Community!
Mi 5
1802 Hours
Mi BandMi KeyI Love MIUIAwesome!Fantastic!MIUI 6Redmi Note 3Mi NoteRedmi 1SXiaomi Mi 4RedmiRedmi NoteMi TVMi 4iDiwali MIUI Fan From IndonesiaMIUI V5 Review1st AnniversarySingapore BirthdayFan Of MIUI IndiaMIUI 4th AnniversaryMIUI Fan from IndiaHappy Valentine's DayMIUI Fan From PhilippinesMIUI Fan from TurkeyMIUI Fan From SingaporeMIUI Fan from MalaysiaHilal Ramadan 2014 ChristmasMIUI Fan From BrazilMIUI 5th AnniversaryMerry Christmas1 Million Forum MembersHappy Singles' DayXiaomi 5th Anniversary300K Forum MembersAlpaca Mi Bunny Summer Mi BunnyI Love Mi BunnyGamer Mi BunnyMIUI Beta team - IndiaForum Contest LoverScroll Of WisdomRedmi Note 3 ExplorerMIUI Global Forum 2014Youth PledgeSuper ModeratorMIUI Twitter FollowerMIUI FollowerPioneer of MIUI English Forum Mr. DependableMIUI Ice Bucket ChallengeHumor MasterMIUI Android 4.4 KitKatAndroid GuruUpdates LoverStar Of IconsRingtone TalentMIUI Community VIP
15:43, Oct-26-2015 | From PC
Awesome work bro...Good thread and most wanted tutorial. Your tutorial will be helpful to all the MIUI ers
Rated by 1 person   Experience Reason
Doraha_Raman + 2 Agreed!
Experience +2  View Rating Log
Active On Mi India Community. Plz PM me on c.mi.com/in
INDIAN SUBFORUM |PRE OTA
Mi 5
1178 Hours
Mi BoxMi In-Ear HeadphonesMi BandMi KeyMi WiFi RouterAwesome!MIUI 2015Fantastic!MIUI 6FlashholicI Love MIUIRedmiRedmi 2Mi 3Mi TVRedmi NoteXiaomi Mi 4Mi Pad2014 Christmas1st AnniversaryFan Of MIUI BangladeshMIUI Fan from MalaysiaHilal Ramadan MIUI 4th AnniversaryDiwali MIUI Fan from IndiaMIUI Fan from TurkeyFan Of MIUI IndiaFan Of MIUI Ex-Yu Happy Singles' DayMIUI Fan From IndonesiaThanksgiving Day300K Forum MembersMIUI 100 Million UsersSingapore BirthdayHappy Valentine's DayXiaomi 5th AnniversaryMIUI Fan From BrazilXiaomi 6th Anniversary700K Forum Members600K Forum MembersFan Of  MIUI Azerbaijan500K Forum MembersSummer Mi BunnyAlpaca Mi Bunny I Love Mi BunnyGamer Mi BunnyMIUI Beta team - IndiaMIUI Beta TeamMi TalentRedmi Note 3 ExplorerHumor MasterYouth PledgeAndroid ElfInbox ZeroForum Contest LoverMi Lover MedalDebate MasterMIUI Android 4.4 KitKatMIUI FollowerDie-hard MIUI FanMost Active MIUIerAndroid GuruMIUI Global Forum 2014MIUI FB FollowerScroll Of WisdomStar Of Icons
15:53, Oct-26-2015 | Via mobile
Awesome  work
Mi 3
49 Hours
Mi Power BankMi In-Ear HeadphonesAwesome!I Love MIUIMIUI 8FlashholicMIUI 7Fantastic!Mi 3Mi 4cHilal Ramadan 1400K Forum MembersUEFA EURO MedalThanksgiving DayMIUI Fan From Vietnam1500K Forum MembersPokemon Master MedalMIUI Fan from Malaysia1 Million Forum MembersGamer Mi BunnySummer Mi BunnyMi Bunny Game Master MIUI FollowerMIUI Android 4.4 KitKatMi Lover MedalDie-hard MIUI FanMIUI FB FollowerForum Contest LoverAndroid GuruTechnology GuruDebate Master
15:56, Oct-26-2015 | From PC
this might fix the connectivity problem i had all along
will try when i flash miui rom again, thanks
Mi 3
118 Hours
Unlock MedalMi Power Bank 10000MAH Mijia Story TellerMi VR HeadsetMi Selfie StickMi Band 2Mi HomeMi In-Ear HeadphonesMi Power BankMi WiFi RouterMi WiFi Router MiniYeelight Bedside LampMagic CubeMi  BunnyMi HeadphonesMijia VR Play 2Mi BandMi VRXiaomi 7th AnniversaryMIUI 2016MIUI 2015MIUI 7FlashholicFantastic!MIUI 6MIUI 8MarshmallowAwesome!I Love MIUIXiaomi Mi 4Mi PadRedmi 3Mi TVMi 3Redmi Note 2Redmi 2Mi 4iMi 4cMIUI Happy Medal1300K Forum MembersMIUI 5th AnniversaryHappy Valentine's DayMIUI Fan From SingaporeXiaomi 5th AnniversaryCamera Filter Guru Medal5 Million Forum PostsMIUI Fan from TurkeyXiaomi 6th Anniversary700K Forum MembersHappy New YearFan Of MIUI BangladeshThanksgiving Day90000 Forum MembersMIUI 100 Million UsersMIUI Fan From IndonesiaMIUI Fan From Brazil800K Forum MembersMIUI Fan From Philippines900K Forum MembersFan of MIUI MyanmarMerry Christmas1 Million Forum MembersHilal Ramadan Happy DiwaliFan Of MIUI Spain1900K Forum MembersMIUI Weekly PollMIUI World Tour3500K Forum MembersFan Of MIUI IndiaSuper MondayDiwali 300K Forum MembersMIUI 2017Fan Of MIUI RussiaSurge S1Puzzle MasterFan Of MIUI ItalyMIUI Lucky Friday2100K Forum MembersI Love 20163 Million Forum App Installs1400K Forum Members1800K Forum MembersOlympics MedalMIUI Fan From MyanmarMIUI Fan From NepalMIUI Fan from IndiaFan Of MIUI UkraineRocket to FuturePokemon Master MedalMIUI Fan From VietnamMIUI 300 WeeksMIUI 6th Anniversary1500K Forum MembersUEFA EURO Medal1700K Forum MembersMid-Autumn FestivalFan Of MIUI GreeceMIUI Fan from MalaysiaMiPopI Love Mi BunnyAlpaca Mi Bunny Gamer Mi BunnyHumor MasterForum Contest LoverMIUI FollowerMIUI FB FollowerMIUI Twitter FollowerDebate MasterStar Of IconsMi Lover MedalAndroid ElfRingtone TalentAndroid GuruTechnology GuruMIUI Android 4.4 KitKatRingtone ExpertStar Of TechnologyMi Story TellerInbox ZeroPioneer of MIUI English Forum Updates LoverMi TalentMIUI Photography GuruDie-hard MIUI FanOTA FeedbackRingtone Star Youth PledgeMi Bunny Game Master MIUI Medals Collector
16:06, Oct-26-2015 | From PC
great tips..thanks for sharing!
MIUI IN MY NERVES
Mi Note 2
815 Hours
Mi BoxMi T-ShirtMi BandMi In-Ear HeadphonesMi KeyMi Band 2MIUI 6Fantastic!MIUI 2016MIUI 7MIUI 8I Love MIUIAwesome!MIUI 2015Mi 4iXiaomi Mi 4Mi Note ProRedmi 3Mi 4cMi NoteRedmi 2Redmi Note 2Mi 5Mi PadRedmi 1SMIUI Fan From PhilippinesHilal Ramadan Fan Of MIUI BangladeshMIUI Fan From SingaporeMIUI 100 Million UsersThanksgiving Day2014 ChristmasHappy Diwali300K Forum MembersDiwali Fan Of MIUI IndiaMIUI Fan from IndiaMIUI Fan from MalaysiaMIUI Fan From BrazilHappy New YearHappy Valentine's DayFan Of  MIUI AzerbaijanMalaysia Anniversary700K Forum MembersFan of MIUI MyanmarMIUI Forum AppMerry ChristmasXiaomi 6th AnniversaryMIUI 6th Anniversary900K Forum Members800K Forum Members1 Million Forum Members1400K Forum Members1500K Forum MembersXiaomi 5th Anniversary1700K Forum MembersAlpaca Mi Bunny I Love Mi BunnyGamer Mi BunnySummer Mi BunnyMiPopMIUI Beta TeamMIUI Global Forum 2014Mi Lover MedalMi Story TellerDie-hard MIUI FanStar Of IconsMIUI FB FollowerRedmi Note 3 ExplorerOTA FeedbackForum Contest LoverMIUI Twitter FollowerMi Bunny Game Master Debate MasterMi TalentMIUI Resources TeamHumor MasterRingtone Star MIUI G+ FollowerScroll Of WisdomRingtone TalentAndroid ElfInbox Zero
16:07, Oct-26-2015 | From PC
Great work bro
Mi 5s Plus
854 Hours
Mi Bluetooth SpeakerMi BandMi Power BankMi WiFi RouterMi HomeMi WiFi Router MiniFantastic!I Love MIUIMIUI 2015MIUI 2016MIUI 7Awesome!MIUI 6Mi TVRedmi Note 3Mi 4cRedmi NoteMi PadRedmi Note 2Redmi 2Mi NoteThanksgiving DayRooster Year of 20172014 ChristmasFan Of MIUI IndiaMIUI 100 Million Users500K Forum MembersMIUI Fan from IndiaMIUI Fan from Malaysia800K Forum Members900K Forum MembersXiaomi 6th AnniversaryMIUI Forum AppMIUI 6th AnniversaryUEFA EURO MedalPokemon Master Medal1500K Forum MembersMid-Autumn FestivalI Love 20161400K Forum MembersMerry Christmas1 Million Forum MembersAlpaca Mi Bunny I Love Mi BunnyGamer Mi BunnyMIUI Beta TeamMIUI Beta team - IndiaForum Contest LoverMIUI Medals CollectorMIUI FB FollowerOTA FeedbackMi TalentRingtone Star Die-hard MIUI FanMi Bunny Game Master MIUI FollowerYouth PledgeHumor MasterRedmi Note 3 ExplorerMi Lover MedalAndroid GuruTechnology GuruAndroid ElfMr. Dependable
16:09, Oct-26-2015 | From PC
Good work....
Keep Smiling he he he..........
Exciting
460 Hours
Mi Plastic In-ear PhonesMi WiFi RouterMi Kids WatchMi HeadphonesMi In-Ear HeadphonesMi VRMi Power BankMi HomeMi Power StripMi  BunnyMi Power Bank 10000MAH Mi VR HeadsetMi Water PurifierMi Band 2Unlock MedalMi MIXXiaomi 6 LaunchMagic CubeMijia Story TellerMijia VR Play 2Mi Bluetooth SpeakerMi BandMijia Qi CycleXiaomi 7th AnniversaryFlashholicMIUI 2016Fantastic!MIUI 6MIUI Devices ContestI Love MIUIMIUI 7Awesome!MarshmallowMIUI 2015MIUI 8AnTuTuRedmi Note 3Mi 5s PlusRedmi NoteRedmi 1SRedmi Note 2Mi 3Redmi 2Mi 4iRedmiMi NoteXiaomi Mi 4Mi PadRedmi 34 Million Forum MembersRocket to Future700K Forum MembersMIUI 5th AnniversarySuper Wednesday3500K Forum MembersHilal Ramadan Super Saturday1900K Forum MembersHappy Valentine's Day900K Forum MembersThanksgiving DayMIUI 2017Rooster Year of 2017MIUI Fan From SingaporeMIUI Font LoverMIUI Weekly Poll800K Forum MembersFan Of MIUI Ukraine300K Forum MembersMIUI Happy MedalMIUI 7th AnniversaryMIUI 9MIUI Fan from IndiaMIUI Fan From Indonesia2014 ChristmasFan Of MIUI IndiaMIUI 100 Million UsersHappy New YearMIUI Fan From BrazilFan Of MIUI Bangladesh600K Forum MembersMIUI Fan from MalaysiaXiaomi 5th AnniversaryPuzzle Master500K Forum MembersDiwali Surge S1MIUI Marathon MedalHappy DiwaliFan Of MIUI RussiaMIUI Fan from TurkeyMIUI World Tour1800K Forum Members1700K Forum MembersUEFA EURO MedalMIUI 300 WeeksI Love 2016Mid-Autumn FestivalPokemon Master MedalFan Of MIUI SpainMIUI Forum AppXiaomi 6th AnniversaryMerry ChristmasMIUI 6th Anniversary1 Million Forum MembersFan of MIUI MyanmarMIUI Fan From Philippines1 Million Forum App InstallsI Love Mi BunnyAlpaca Mi Bunny Gamer Mi BunnyMiPopSummer Mi BunnyMIUI Beta TeamMIUI ReviewDie-hard MIUI FanYouth PledgeStar Of TechnologyMIUI FollowerMIUI FB FollowerMIUI Android 4.4 KitKatMi Story TellerRingtone Star Mi Bunny Game Master Android ElfDebate Master2017 Annual AwardsMIUI Global Forum 20146 Million Forum MembersRingtone TalentPioneer of MIUI English Forum App StarMIUI Resources TeamMIUI Halloween 2017OTA FeedbackMIUI KingMIUI Twitter FollowerInbox ZeroHumor MasterMIUI G+ FollowerWallpaper TalentMIUI Medals CollectorTechnology GuruAndroid GuruApp TalentApp TalentMaster Of TechnologyUpdates LoverScroll Of WisdomForum Contest LoverMi TalentMi Lover MedalMIUI ExpertTheme Talent
16:12, Oct-26-2015 | From PC
Mi 4i
16 Hours
Unlock MedalMi Band 2Thanksgiving DayI Love 2016MIUI 9MIUI 2017MiPopForum Contest LoverOTA Feedback
16:13, Oct-26-2015 | From PC
This post was edited by hafira90 at 16:16, Oct-26-2015
awesome! I always struck with this issues, I thought it was the carrier problem. Will now try this method right away sir! Thank you so much!
edit; I notice that it was for Mi3/Mi4.. can it be used for Mi 4i?
Comment
miui-guru use the root file explorer method - rooted phone + es file explorer then follow the above guide  16:44, Oct-26-2015
MIUI Beta Team - Global
Mi 5
431 Hours
Unlock MedalMIUI 7MIUI 2016Fantastic!Redmi 3Xiaomi 6th Anniversary1 Million Forum MembersMIUI Fan from India800K Forum MembersMIUI Beta team - IndiaDebate MasterAndroid GuruInbox ZeroMi Bunny Game Master Star Of IconsTechnology GuruMr. DependableMi Lover MedalAndroid ElfDie-hard MIUI FanForum Contest LoverYouth Pledge
16:14, Oct-26-2015 | Via mobile
Thanks
