Mi Note Pro
180 Hours
Mi Power BankMi In-Ear HeadphonesMi WiFi RouterMi BandMIUI 7Awesome!MIUI 6Mi 4iRedmi Note 2Mi Note ProMi 4cRedmi ProMIUI 5th AnniversaryMIUI Fan From SingaporeHilal Ramadan 700K Forum MembersHappy Valentine's DayMIUI Fan From Indonesia900K Forum MembersMIUI Fan from India800K Forum MembersMIUI 100 Million UsersI Love Mi BunnyMIUI Beta TeamDebate MasterForum Contest LoverMi TalentDie-hard MIUI FanHumor MasterScroll Of WisdomMIUI Twitter FollowerMIUI G+ FollowerMIUI Medals Collector
[Tools, Tips & Tutorials] [GAPPS][AROMA] 64bit Gapps for Mi Note Pro (Android 5.0.x & 5.1.x)
40104 780 |
17:04, Sep-30-2015 | From PC
This post was edited by Kahun at 16:51, Dec-10-2015
So have you got your amazing Mi Note Pro but you are missing Google Apps? No problem! It's quite simple all you need to do is flash Google Apps on your phone. Please follow this guide to successfully install Google Appps.
This is for Mi Note Pro (leo)
Disclaimer:
I'm not responsible for any devices being bricked, your device blowing up or world war 3 starting! You are doing this at your own risk.
Download Links:
  Please reply to view this thread.
INSTALLING GAPPS USING STOCK MI-RECOVERY WILL NOT WORK PLEASE INSTALL TWRP TEMPORARLY OR PERMANENTLY
If you already have TWRP installed you know what to do..
Download the following file:
HOW TO INSTALL TWRP TEMPORARLY
1. Save the file on your PC.
2. Power off your device and turn it back on by holding Power button and Volume Down at the same time. This will get you into fastboot menu.
3. Now what you will have to do is plug your phone to your PC using a usb cable.
4. Open up the Command Promt and navigate to the location of your fastboot driver. Mine is C:/adb so I would type cd C:/adb in the command promt
5. Now type in fastboot devices just to make sure that your device is listed correctly.
6. Place the twrp.img inside same folder as fastboot.
7. Type fastboot boot twrp.img (TO FLASH PERMANENTLY USE ''fastboot flash recovery twrp.img'')
8. Now your phone should boot into TWRP!! Click on the Install button and then navigate to where you have saved the Gapps package
9. Reboot and you are should have Gapps correctly installed.
FAQ:
1. What if I get Error Code 40?
This means that you have already a Gapps package installed. To fix this download a root unistaller app that can unistall system apps and remove Google Play Services & Google Play Store.
#70 - Insufficient Space Available in System Partition: Your device does not have sufficient space available in the system partition to install the Open GApps package.
Try flashing the pico package instead as it is a lot smaller in size.
https://mega.nz/#!aQVxCSZQ!y5lmshZrdkwvH2qvkbiYNyCrfAS5JdegbpLFu3wAGRY
To be continued..
Favorite11 Share
Rated by 15 people   Experience Prestige Reason
BoceMiPad + 2 Thanks!
andrey@records + 2 Thanks!
CarpetHell + 1 Спасибо!
moeztuerk + 2 Thanks!
nik2670 + 1 Agreed!
garyw7 + 1 Thanks!
Dasari5 + 1 Thanks!
graynoize + 1 Thanks!
Mati69ase + 1 Awesome!
teejay456 + 10 + 1 Great!
Svarog.bu + 1 Thanks!
edypurwanto + 5 Thanks!
ThawThaw + 10 + 3 Thanks!
GR33dyBlackie + 10 + 3 Awesome!
magullo + 2 Thanks!
Experience +50  Prestige +7  View Rating Log
Mi MIX
354 Hours
Mi HeadphonesMi Power BankMi WiFi Router MiniUnlock MedalMi T-ShirtMi BandMi In-Ear HeadphonesMi HomeXiaomi 7th AnniversaryMarshmallowAwesome!MIUI 2015Fantastic!MIUI 2016MIUI 7I Love MIUIMIUI Devices ContestRedmi ProRedmi NoteMi 5Redmi 2Mi Note ProMi PadRedmi Note 2RedmiMIUI 9MIUI 7th AnniversarySuper TuesdayMerry ChristmasThanksgiving Day900K Forum Members800K Forum MembersMIUI Fan from MalaysiaMIUI Lucky Friday300K Forum MembersHappy New YearMIUI 4th Anniversary700K Forum MembersMIUI Fan From PhilippinesHappy Valentine's DaySuper SaturdayMIUI Fan From SingaporeMIUI 5th AnniversaryMIUI Fan from IndiaFan of MIUI MyanmarRocket to FutureFan Of MIUI IndiaHappy Diwali1400K Forum MembersMIUI Forum App90000 Forum MembersMIUI V5 Review3 Million Forum App Installs100k Forum MembersMIUI 20172100K Forum MembersSuper Thursday1900K Forum MembersMIUI 300 WeeksUEFA EURO MedalMIUI Fan from Turkey1 Million Forum MembersXiaomi 6th AnniversaryXiaomi 5th AnniversaryFan Of MIUI Ex-Yu Alpaca Mi Bunny Summer Mi BunnyI Love Mi BunnyGamer Mi BunnyMiPopMIUI Device TeamMIUI FollowerPioneer of MIUI English Forum MIUI Weekly Devices QuizInbox ZeroStar Of TechnologyDebate MasterMaster Of TechnologyMi Lover MedalMIUI ExpertUpdates LoverTechnology GuruMi Story TellerAndroid ElfMIUI FB FollowerRingtone TalentScroll Of WisdomDie-hard MIUI FanMost Active MIUIerMIUI G+ FollowerMIUI Twitter FollowerForum Contest LoverMi TalentAndroid Guru
18:24, Sep-30-2015 | From PC
Thanks man, and great catch for being a Moderator!
Rated by 1 person   Experience Reason
Kahun + 10 Thanks!
Experience +10  View Rating Log
If I helped you, a simple thanks would be really appreciated. Pay me a soda.
Junior Member
3 Hours
00:24, Oct-01-2015 | Via mobile
Thank you
4 Hours
09:12, Oct-01-2015 | From PC
Thanks so much...
4 Hours
09:17, Oct-01-2015 | From PC
gapps links are dead, pls update.
Mi Note Pro
16 Hours
13:29, Oct-01-2015 | From PC
yes all working well.
thanks
Mi 4
31 Hours
Mi NoteMIUI Fan From Indonesia
13:48, Oct-01-2015 | From PC
thank you
6 Hours
13:51, Oct-01-2015 | From PC
Great work!
Mi Note Pro
180 Hours
 Author| 14:55, Oct-01-2015 | From PC
JayShenTahoe replied at 2015-10-1 09:17
Will update in a minute cheers
Mi Note Pro
180 Hours
 Author| 16:29, Oct-01-2015 | From PC
Updated with new MEGA links
